[FS] Netherlands - 2x LAB Gruppen PD3000 amplifiers [NEW] (2x600,- = 1200,-)
Oct 1, 2022
5
Zandvoort, The Netherlands
€600,- per piece / 2 for €1200,-
3000 Watt Two-Channel Amplifier with Power Management​
  • Power: 1000 W @ 2 Ohm, 1500 W @ 4 Ohm, 800 W @ 8 Ohm
  • Type of amplifier: Class-D
  • X-Over modes: LF / Full Range / HF, switchable
  • Crossover frequency: 100 Hz
  • THD + N (20Hz - 20 kHz, 1dB below clip): <0.1%
  • Signal-to-noise ratio:> 90 dB
  • Channel separation (crosstalk @ 1kHz):> 75 dB
  • Frequency response 10 Hz - 20 kHz (+ 0.5 / -1 dB)
  • Input impedance: 10 kOhms unbalanced, 10 kOhms balanced
  • Total harmonic distortion (1/8 nominal power): <0.1%
  • Power consumption (@ 4 ohms): 1050 W.
  • Inputs: 2x XLR / 2x 6.3 mm TRS jack
  • Outputs: 2x Neutrik SpeakOn
  • Dimensions (H x W x D): 93 x 483 x 326 mm
  • Weight: 6.5 kg
Never used
