Hi Everyone,
I have started work on the 60 degree version. Don has helped once again and provided some preliminary CAD drawings. A bit of work is still needed to simplify the construction and finalize the dimensions.
The original DIY was a prototype designed to test the design and concept; this time I’m planning to make a “proper box” and provide some more construction details and drawings from the start.
The 60 degree version will be about 20mm deeper than the 90 degree version because of the extra depth of the Eighteen Sound XT1464 horn. I may also have to make the box about 8mm wider. To offset the slight increase in size I plan to cut the back corners off. This is mostly cosmetic a should make the box look smaller from most angles.
It’s likely that the 60 degree version will be used in pairs, accordingly I have done a SIM for two boxes at the AES peak power (+6 dB on the RMS rating). To do this I modelled one box in half space.
I thought it would be appropriate to start a new thread which is more focused on the construction of the box unlike the original DIY Mid Hi thread – Bennett I hope that’s OK.
I have provided some SIM’s using the RCF and the B&C's 12NDL76. It shows the power response (dark line) and the the SPL corrected for directivity (grey line).
Note: the low frequency section of SPL curve is my best guess; Horn Response can not model the directive of the reflex ports
Peter
Peter
