Fremont, CA – June 2020… ARISTA Corporation, recognized globally as a leading manufacturer of professional audio products, AV extenders, matrix switchers, and related products for the professional audio and AV installation markets, is pleased to announce the E-Vocal ARS-1616S-A00 and ARS-1616S-A10 multiple channel analog input and analog output Dante-equipped stage boxes. These rugged standalone units, the size of a 3U rackmount enclosure, are the ideal solution for connecting as many as 16 analog microphones and other audio sources and then feeding a mixing console via Dante using a single Ethernet cable—dramatically streamlining stage setups for live performers.
The ARS-1616S Series Stage boxes are available in two versions: the ARS-1616S-A10 incorporates -8 dB to 34 dB preamp gain control with Phantom Power while the ARS-1616S-A00 does not and would require a separate preamp. In addition to their ability to convert 16 analog audio sources to a Dante stream, the...
Continue reading...
