Audio Architect + BLU-50 configuration
Wes Fornier
2
France
Hello, I am contacting you because I have a problem connecting a DSP (BLU-50) to the internet. I have almost no knowledge of music but good network skills. I tell you what I want to do
I would like to access my DSP to cross the internet in order to modify the remote settings. I use the "Audio Architect" program.
I encounter the following problem: I can't find any way to connect this damn DSP in the program.
On the network side, I think everything is ok, I attracted a fixed IP to the DSP, and I assigned it a redirect port in TCP and UDP.
So I'm a bit stuck.
  • Can I connect this model of DSP to the internet by plugging it directly into the modem?
  • Does Audio Architect allow you to connect to a DSP other than locally?
    Thank you for your answers :).
Ps: I know it's a profesional forum, but i found no where else to post my problem, if you don't want to answer to it i'll delete my post. Anyway thank you again !
Hello Rob, thank you for that answer. To be honnest that was my first idea, the only problem is that there is nowhere to add a vpn file because i'd like to be directly connected beside the modem...
He is a short diagram, maybe it could better for understanding :)
