Located in Biloxi, MS
Single space, 8 channel mic/line mixer.
http://c353616.r16.cf1.rackcdn.com/801_Operation_Manual.pdf
Sell it for $400 with 48 State delivery included
The 801 is a single rack-space mixer, with eight mic/line inputs and one auxiliary line input. Each mic/line channel uses a differentially balanced, discrete transistor preamplifier for low noise and low distortion performance.
Special features, including a limiter and remote level control, make the 801 extremely versatile. The 801 mixer is dependable, easy to install, simple to operate, and carries a five-year warranty.
801 features include:
eight differential balanced mic/line inputs & one aux line input
discrete transistor mic/line preamps for low noise & distortion
optional mic/line input isolation transformers (user installed)
+24 volt phantom power selectable on each mic/line input
optional +48 volt phantom power supply (user installed)
aux input switch selectable for balanced or stereo summing
aux input 'auto-ducking' switch selectable on channels 1~8
front panel trim and rear panel pad switch on each channel
+10dB 'peak' LED indicator on each channel for easy set-up
high-pass 'rumble' filter switch selectable on each channel
mic/line & aux inputs on plug-in barrier strip connectors
1/4" patch insert jack on each channel and at main output
balanced main output on plug-in barrier strip connector
main output limiter with threshold control and LED indicator
main out Bass & Treble control with rear panel bypass switch
-20dB signal present & power LED indicators at main output
channel 1 / priority override via rear panel switch terminals
optional remote control of main out via external level control
optional main output isolation transformer (user installed)
stack in & slave switch to add inputs by linking multiple units
DC Out jack for powering certain other BIAMP products
covered by Biamp Systems' five-year warranty
marked and
UL/C-UL
listed power source
marked and
UL/C-UL
listed power source
