Marketplace
Biamp 801 mic/line mixer
<blockquote data-quote="Rain Jaudon" data-source="post: 7645" data-attributes="member: 49"><p>Located in Biloxi, MS </p><p></p><p>Single space, 8 channel mic/line mixer.</p><p><a href="http://c353616.r16.cf1.rackcdn.com/801_Operation_Manual.pdf" target="_blank">http://c353616.r16.cf1.rackcdn.com/801_Operation_Manual.pdf</a></p><p></p><p>Sell it for $400 with 48 State delivery included</p><p></p><p></p><p>The 801 is a single rack-space mixer, with eight mic/line inputs and one auxiliary line input. Each mic/line channel uses a differentially balanced, discrete transistor preamplifier for low noise and low distortion performance.</p><p>Special features, including a limiter and remote level control, make the 801 extremely versatile. The 801 mixer is dependable, easy to install, simple to operate, and carries a five-year warranty.</p><p> </p><p>801 features include:</p><p>♦</p><p>eight differential balanced mic/line inputs & one aux line input</p><p>♦</p><p>discrete transistor mic/line preamps for low noise & distortion</p><p>♦</p><p>optional mic/line input isolation transformers (user installed)</p><p>♦</p><p>+24 volt phantom power selectable on each mic/line input</p><p>♦</p><p>optional +48 volt phantom power supply (user installed)</p><p>♦</p><p>aux input switch selectable for balanced or stereo summing</p><p>♦</p><p>aux input 'auto-ducking' switch selectable on channels 1~8</p><p>♦</p><p>front panel trim and rear panel pad switch on each channel</p><p>♦</p><p>+10dB 'peak' LED indicator on each channel for easy set-up</p><p>♦</p><p>high-pass 'rumble' filter switch selectable on each channel</p><p>♦</p><p>mic/line & aux inputs on plug-in barrier strip connectors</p><p>♦</p><p>1/4" patch insert jack on each channel and at main output</p><p>♦</p><p>balanced main output on plug-in barrier strip connector</p><p>♦</p><p>main output limiter with threshold control and LED indicator</p><p>♦</p><p>main out Bass & Treble control with rear panel bypass switch</p><p>♦</p><p>-20dB signal present & power LED indicators at main output</p><p>♦</p><p>channel 1 / priority override via rear panel switch terminals</p><p>♦</p><p>optional remote control of main out via external level control</p><p>♦</p><p>optional main output isolation transformer (user installed)</p><p>♦</p><p>stack in & slave switch to add inputs by linking multiple units</p><p>♦</p><p>DC Out jack for powering certain other BIAMP products</p><p>♦</p><p>covered by Biamp Systems' five-year warranty</p><p>♦</p><p>marked and</p><p>UL/C-UL</p><p>listed power source</p></blockquote><p></p>
[QUOTE="Rain Jaudon, post: 7645, member: 49"] Located in Biloxi, MS Single space, 8 channel mic/line mixer. [url]http://c353616.r16.cf1.rackcdn.com/801_Operation_Manual.pdf[/url] Sell it for $400 with 48 State delivery included The 801 is a single rack-space mixer, with eight mic/line inputs and one auxiliary line input. Each mic/line channel uses a differentially balanced, discrete transistor preamplifier for low noise and low distortion performance. Special features, including a limiter and remote level control, make the 801 extremely versatile. The 801 mixer is dependable, easy to install, simple to operate, and carries a five-year warranty. 801 features include: ♦ eight differential balanced mic/line inputs & one aux line input ♦ discrete transistor mic/line preamps for low noise & distortion ♦ optional mic/line input isolation transformers (user installed) ♦ +24 volt phantom power selectable on each mic/line input ♦ optional +48 volt phantom power supply (user installed) ♦ aux input switch selectable for balanced or stereo summing ♦ aux input 'auto-ducking' switch selectable on channels 1~8 ♦ front panel trim and rear panel pad switch on each channel ♦ +10dB 'peak' LED indicator on each channel for easy set-up ♦ high-pass 'rumble' filter switch selectable on each channel ♦ mic/line & aux inputs on plug-in barrier strip connectors ♦ 1/4" patch insert jack on each channel and at main output ♦ balanced main output on plug-in barrier strip connector ♦ main output limiter with threshold control and LED indicator ♦ main out Bass & Treble control with rear panel bypass switch ♦ -20dB signal present & power LED indicators at main output ♦ channel 1 / priority override via rear panel switch terminals ♦ optional remote control of main out via external level control ♦ optional main output isolation transformer (user installed) ♦ stack in & slave switch to add inputs by linking multiple units ♦ DC Out jack for powering certain other BIAMP products ♦ covered by Biamp Systems' five-year warranty ♦ marked and UL/C-UL listed power source [/QUOTE]
Marketplace
