CAMCO VORTEX 6 Power Amplifier (2 AVAILABLE) $900 EACH
CONDITION DESCRIPTION
This is a great sounding amplifier that's in good working order and good condition.
FEATURES
Total precision and transparency is the trademark of the Vortex series, thanks to its careful design eliminating sound-deteriorating drawbacks right from the start. This is also evident in the Vortex Series exceptional low distortion values and excellent signal to noise ratio.
SPECIFICATIONS
⦁ Output Circuitry: Bipolar, Class H
⦁ Input Impedance: 40k balanced
⦁ Input gain: selectable: 26dB, 32 dB, or 1.4 V input sensitivity
⦁ Limiter: 3 step switchable peak-limiter
⦁ Fan: 2 temperature dependant speed-controlled axial fans
⦁ Ground-lift: input ground-lift switch on back panel
⦁ Indicators: LED’s for ON, SIGNAL, CLIP, DC, High Temp, Output Current
⦁ Protection circuit on / off transients, undervoltage, DC / Subsonicsignale
⦁ Dimensions (WxHxD): 483 x 88.9 x 420 mm (19 ", 2 HE )
⦁ Weight: 12.4 kg
FEATURES
SPECIFICATIONS
⦁ Weight: 12.4 kg
