Hello all. I'm new here, so I just have to hope this is a good place to ask about this. I'm having an electronics engineering type of problem.
I'm trying to figure out how to make myself a mute switch and volume adjustment, either in the same unit or with the mute on my pocket and the adjuster on the floor. The fun part is that I use a condenser-based instrument mic that needs 48V phantom power, so anything I use has to pass that voltage. That also means I can't convert any line-based gear.
The volume control is what's really throwing me for a loop. I know very few normal pots can survive 48V, so I need an alternative. I know there are rheostats that can take that voltage - can they be used in this application? Are there any other types of variable resistors I should look at?
Also, I don't know how I would go about wiring such an adjuster - I'd be concerned that it might make a lot of noise if I run it the same way as guitar stuff. Can anyone help me there?
Thanks.
P.S. I do know a bit more about engineering than your average musician, and I have relatives with all manner of engineering degrees if you toss me something I don't understand.
Thanks.
