MiniDSP is great, but it doesn't provide a great solution for pro audo loudspeaker applications. Does anyone have a good solution for a FIR capable DSP with balanced line level I/O?
Thanks.
Thanks.
I saw that, but I'm really looking to do FIR taps for this project.If it's just balanced I/O you're after, there is a balanced version of the Minidsp. Although the webpage claims IIR only, the manual has information on how to load custom biquad filters.
[/URL]
So they have all the features required make perfect settings for the your PM boxes.As a crossover / processor absolutely. I think I'm getting even better results![]()
The Lake may still has advantages in terms of being a system tool with its groups, Mesa EQ and its easy to use brick wall filters etc.
There is also the DRAC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.MiniDSP is great, but it doesn't provide a great solution for pro audo loudspeaker applications. Does anyone have a good solution for a FIR capable DSP with balanced line level I/O?
Thanks.
There is also the DDRC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.
At that price point, we're well into the professional market. Defeats the purpose.There is also the DRAC-88 series which use the miniSHARK module for FIR processing, its 8 in 8 out both balanced and unbalanced.
