Electrovoice dc one
Spyros Vlachos
2
Greece
Hi guys.
I have an issue with unlock function.
I don't remember the 4 digit code that i set at this prossecor.
Is there a general master code unlocking it?
Thanks in advance!
Ps. Panel + usb lock is indicated
Both functions are locked (panel + usb)
So i can do nothing from there.
I wonder if there is a jumper or something on the mainboard to factory reset it.
At ev dx 38 that'the way to hard reset it.
I think you can just use the GUI tool to unlock it, or if nothing else reset it and start from scratch.
I don’t know the reset sequence for that unit but most DSPs have a way to reset them. But if you do that it usually erases all of the presets in the unit. So if you can connect to it and see all the setting you may need to write them all down and when you find the reset sequence then you will need to enter all of the setting back into the unit. If you can save the settings to you computer hooked up to the unit in some other place on the computer you may be able to reload those setting after it has been wiped clean from the unlock reset.
But maybe there isn’t a way to reset it http://forums.prosoundweb.com/index.php?topic=3495.0
Another thread about the DC-One https://forums.prosoundweb.com/index.php?topic=124422.0
Hi guys.
Thanks in advance!
Hello I’m sure your question was answered but if not there’s a master code to unlock it the code is 4301 hope that helps someone
