Lighting & Electrical
Event Power, problems, observances, etc.
<blockquote data-quote="Ian Coughlin" data-source="post: 3780" data-attributes="member: 19"><p>As the size of my gigs grow so does the power demand. I find myself thinking about power distro more often with out a clear answer to my problem. </p><p></p><p>Currently I'm leaning towards an L21-30 solution because a few of my regular clients have or can install these receptacles and it is sufficient for my current and near future power needs.</p><p></p><p>On the flip side I've noticed a lot of large catering halls don't have anything more than a few 5-15's and can't tell me if they are dedicated or not. It amazes me how some of these "newer" catering halls spend thousands if not millions of dollars renovating or building the venue and fail to address the needs of one of the most important features of any party, THE LIGHTING AND SOUND! Do they really think that three duplex 5-15's are sufficient for the grand ball room with a 500 person capacity?!</p><p></p><p>I actually had a gig last night and had this problem. The gig was at Tosca's Marquee in Brooklyn, and is a relatively new building. It was partially my fault for not going to the venue personally to check it out but the manager assured me over the phone that "there is plenty of power, DJs play here all the time". When I arrive on location I ask them where I can pull power from and the guy points at a single 5-15 receptacle on the wall. Mind you I'm bringing in four 300w movers, two data flashes, four color blast 12s, and a DJ rig of QSC KW121's, and 181's. When I asked if there was more than one and if they were dedicated he didn't know. He then showed me the panel, which was very neatly labeled where I discovered a single 20A breaker for "Dinning Room" and two other 20's for the foyer. Luckily for me I had a full AC case and plenty of cord to make the 100'+ runs for the movers. The data flashes weren't so lucky and wouldn't charge up sharing the same circuit as the audio.</p><p></p><p>Why can't these venues install a small panel, weather it be a disconnect, sub panel, miniature company connect box, etc. in these bigger rooms? If they could what would be a good "standard", L21-30s? L14's? L5's?</p><p></p><p>Ian</p></blockquote><p></p>
[QUOTE="Ian Coughlin, post: 3780, member: 19"] As the size of my gigs grow so does the power demand. I find myself thinking about power distro more often with out a clear answer to my problem. Currently I'm leaning towards an L21-30 solution because a few of my regular clients have or can install these receptacles and it is sufficient for my current and near future power needs. On the flip side I've noticed a lot of large catering halls don't have anything more than a few 5-15's and can't tell me if they are dedicated or not. It amazes me how some of these "newer" catering halls spend thousands if not millions of dollars renovating or building the venue and fail to address the needs of one of the most important features of any party, THE LIGHTING AND SOUND! Do they really think that three duplex 5-15's are sufficient for the grand ball room with a 500 person capacity?! I actually had a gig last night and had this problem. The gig was at Tosca's Marquee in Brooklyn, and is a relatively new building. It was partially my fault for not going to the venue personally to check it out but the manager assured me over the phone that "there is plenty of power, DJs play here all the time". When I arrive on location I ask them where I can pull power from and the guy points at a single 5-15 receptacle on the wall. Mind you I'm bringing in four 300w movers, two data flashes, four color blast 12s, and a DJ rig of QSC KW121's, and 181's. When I asked if there was more than one and if they were dedicated he didn't know. He then showed me the panel, which was very neatly labeled where I discovered a single 20A breaker for "Dinning Room" and two other 20's for the foyer. Luckily for me I had a full AC case and plenty of cord to make the 100'+ runs for the movers. The data flashes weren't so lucky and wouldn't charge up sharing the same circuit as the audio. Why can't these venues install a small panel, weather it be a disconnect, sub panel, miniature company connect box, etc. in these bigger rooms? If they could what would be a good "standard", L21-30s? L14's? L5's? Ian [/QUOTE]
