Junior Varsity
Fuzzy Beta 58
<blockquote data-quote="Tim Weaver" data-source="post: 2431" data-attributes="member: 317"><p>I've got an old beta 58 that has developed a distortion that almost sounds like a guitar's fuzz stomp box. I took the ball off and discovered that the foam that is normally glued to the capsule is completely rotten and has fallen off. Could it be the missing foam causing the distortion, or do you think I should just send it off and be done with it? The foam inside the ball is brand new, btw.</p></blockquote><p></p>
[QUOTE="Tim Weaver, post: 2431, member: 317"] I've got an old beta 58 that has developed a distortion that almost sounds like a guitar's fuzz stomp box. I took the ball off and discovered that the foam that is normally glued to the capsule is completely rotten and has fallen off. Could it be the missing foam causing the distortion, or do you think I should just send it off and be done with it? The foam inside the ball is brand new, btw. [/QUOTE]
Junior Varsity
Fuzzy Beta 58
