I'm looking for the cut-to-the-chase wiring-up of 2 QSC KW181's & 2 QSC K12.2's per side. We have one main XLR coming from the board for each side. Then I just want to confirm which inputs & outputs I use to hook up the two subs and two tops correctly. I assume its KW181 > KW181 > K12.2 > K12.2 but I want to be absolutely sure I'm using the correct inputs/outputs on each box. I'm also looking for confirmation that my box sequence above is actually correct. Please help - I don't really need the whys, I just need the cut to the chase "Board to Input X on Box X, then our of Box X using X output jack to Box Y's Input Jack, then Box Y using Y output, to Box Z input and so on"
Can anyone give me a brief bullet pointed list? The only detail I need is box sequence and specific names of the input and output jacks. We use XLR. Pictures of panels are attached.
Thank you!!
Thank you!!
