LS9-32 & IT input level meters don't match
Is there a way to bump up the master level meter on an LS9-32 to match the input meters on the IT amps?
Right now, when the LS9-32's meters are at -18, the IT's input meters are at clip and the outputs are touching Limits. This doesn't bother me with the mixer outs showing so low on the board
However, when a BE works on the desk they want to run the mixer close to the clip lights on the board. Inorder to make him happy for the night I backed down the IT levels down 18-20 db per amp (but that only affected the out levels and the Input meter stayed in Clip the entire time).
I think my IT amps input are set to 1.4v with analog inputs.
Re: LS9-32 & IT input level meters don't match
I'm running my IT amps at 32db.
In SA under the source icon there is the input sensitivity in volts and db, they change when you play with the input gain, and under that is the db range in dbu. This range is only 15 and 26db
