Lumen Loss with Short Throw lens
Ben Lawrence
Senior
Mar 2, 2011
1,185
29
48
Vermont
vtaudiovisual.com
I have a projector with a Short Throw lens on it. It seems like I remember it being brighter when I had the standard lens mounted in a similarly lit room.
Is there a loss in Lumens associated with using a short throw lens compared to a "standard" lens?
Two things I can think of
1) lamps get dimmer over time
2) lenses do not all have the same light transmittal. There is an f stop value associated with a lens. The lower the number, the more light gets through. Low values are more expensive as they require more expensive glass.
Sent from my iPad HD
Cool thanks for the response. I swapped out for the standard lens and the brightness was similar. The short throw lens was not cheap so doubting it has a significant light loss. It does create a bit more of a hot spot with rear projection though.
