Junior Varsity
M32C Inputs and Effect Limits
<blockquote data-quote="Tim McCulloch" data-source="post: 218464" data-attributes="member: 67"><p>In a word, no... not at the same time.</p><p></p><p>The default XLR patching has buses 13 & 14 on XLR outputs 13 & 14, with XLR outputs 15 & 16 patched to main L & R. While EFX 1 is patched to BUS 13, you don't have to use it. You can unpatch it in the EFFECTS EDIT, or dedicate that effects slot to a channel or bus insert without using a bus for the send.</p><p></p><p>Experiment using X32 Edit (download from Behringer) for Win/Mac/'nix to see how this works before you start making changes to your mixer, but if you only need 2 effects you should be golden.</p></blockquote><p></p>
[QUOTE="Tim McCulloch, post: 218464, member: 67"] In a word, no... not at the same time. The default XLR patching has buses 13 & 14 on XLR outputs 13 & 14, with XLR outputs 15 & 16 patched to main L & R. While EFX 1 is patched to BUS 13, you don't have to use it. You can unpatch it in the EFFECTS EDIT, or dedicate that effects slot to a channel or bus insert without using a bus for the send. Experiment using X32 Edit (download from Behringer) for Win/Mac/'nix to see how this works before you start making changes to your mixer, but if you only need 2 effects you should be golden. [/QUOTE]
Junior Varsity
