Sound Forums News
Administrator
Staff member
Apr 6, 2018
London, UK – May, 2020. After 28 years of consistent touring, the Stereophonics’ relentless quest to improve their stage sound and gain closer engagement with their audience continues.
At the request of the band, and specifically Kelly Jones, their sound techs were sent into overdrive, working on a radical approach for the latest arena tour. Long-term FOH sound engineer Dave Roden, using his preferred Martin Audio MLA loudspeaker array, sent his mix to a distributed PA system, running the length of a 60ft thrust from main stage, into the belly of the audience, with a small ‘B’ stage at the end of it.
By opting to play a third of their set right in the middle of the arena (including a solo Kelly Jones set), it would have left the band at risk of absorbing unwanted sounds off the main PA picked up by the vocal mics, had it been set in a conventional L/R configuration. At the same time, performing so far in front of the PA would have required substantial EQ changes, which would...
Continue reading...
