Measurement Rig
Tom Hester
Southern California
So what is the haps with Smaart rigs these days? I know it used to be a M30 and USBpre was the way to go. Looking to make a few purchases for very simple measurements/alignments. I already own a Macbook Pro 2.53 with 4g of ram.
Smaart 7 the way to go? or should I go with a older version? (if possible)
Thanks
Tom
Re: Measurement Rig
Smaart 7 is my preference, much faster and easier to use, plus higher resolution MTW measuring.
I have a $800 mic, and I have a $100 mic. Guess which one goes on the stand in the middle of the dusty shed?
I prefer MOTU's Ultralite and Traveler for interfaces. Digitally recallable preamp gain.
Re: Measurement Rig
Once you go multichannel, you never go back!
My current test configuration:
MacBook Pro 17'' 2.8 GHz, 8GB Ram
Smaart 7
Roland Octa-Capture (a great 8 mic pre interface)
6 Smaart RTA-420 (considering upgrading to Audix TM-1)
1 Earthworks M30
1 Quest CA-22 Calibrator with custom mic adapters from Harry
1 Neutrik MR-1 Signal Generator
1 iPod Classic with a bunch of wav file music test tracks
1 iPhone with AudioTools & iAudioInterface, and of course Angry Birds app while waiting for the lampies to get their stuff done so I can tune the system!
Re: Measurement Rig
Thanks
Tom
I am running Smaart 7 and Systune with a MOTU 8 pre and 8 Earthworks M23 mics and Windows. I have a measurement cart that contains all my mic cable reels and mic stands and provides a work table.
I also use the Audio Toolbox polarity tests as a pulse generator for listening to arrival times.
Wave files for final listening.
Re: Measurement Rig
Smaart 7
1 Earthworks M30
I suggest some variation of Arthur's recommendations. Smaart 7 is the best version of Smaart for many reasons, the main one being it's multichannel.
Focusrite Saffire Pro40
4 - 6 Apex220 mics. Upgrade to TM-1 or Beyerdynamic MM1.
1 - TM-1 or Beyer MM1. Upgrade to SoundFirst101
Grant
Re: Measurement Rig
Hey
I'm running,
Smaart 7
Edirol UA101 (for dual channel)
or RME Fireface 800 (multi channel)
Mic wise have the Earthworks s30 and a Behringer Measurement mic. (traces were the same for both but the earthworks was 6db hotter.) so tend to use the Behringer in the field.
I found running direct in to the Edirol with the earthworks was very hot to the point that when the gain was right down on both the measurement and the reference I was still clipping the inputs when run at show level. for running show level stuff I got a couple of inline pads that pass phantom put it in on both the measurement and reference to effect both the same. this put them in a controllable area of the sound card input. (anyone got any reason why this isn't a good thing? would love to hear from you) It does the trick for what I'm using it for.
Re: Measurement Rig
As long as it doesn't alter the frequency response, I see no problem with putting a pad on the mic input.
Re: Measurement Rig
Smaart 7, SysTune and EASERA
Two Earthworks M30 and one Sound First SF111 (Type 1) Mics
EASERA Gateway (modified PreSonus FireBox)
Cirrus CR:511E Calibrator
Sencore SP395
Dayton Audio WT3
IPod with sweeps, dry signals, word tests, music, etc.
Zoom H4 Recorder
Re: Measurement Rig
Just out of curiosity. Is it possible to purchase an older version? I tried looking online, but all I found were illegal downloads, and I am not into that. If i need to, I will buy 7, but its hard to justify $900 for very simple measurements. (I know, I know, you get what you pay for) I'm not typically the guy cheaping out, but being newly married, I have to justify expenses to ''the boss''.
Thanks Guys.
Re: Measurement Rig
Thanks Guys.
S7 is a real deal ... $900 ? ... It'll only hurt for a week .... later on you'll prove to be more solid than ever before ... in your system setups, of course
<font size="1">trust me, I know</font> !!
Re: Measurement Rig
I remember buying my first copy of Smaart when I started out on my own 10 years ago. Yes it hurt when combined with the cost of the USBPre and Earthworks M30, but I recouped that cost in added income within a few months.
Re: Measurement Rig
Has anybody used the DPA 4090 mics for measurement?
I'm curious about this too. Bob McCarthy had this to say about them on PSW:
Quote: said:
The reason I stated that I would have gone with ( and may at some in the future go with) the low cost DPA's is more relational, than purely technical. I have used Bruel & Kjaer (and now DPA) mics so much over the years and been let down so few times..........so few that I can hardly think of even once. I think of them as digital mics - 1 or 0 - working perfectly or dead (and this is usually easy to spot with the crushed head.)
I just have so much confidence in their mics that I would feel confident relying on them - and inevitably we RELY on mics. But, all that said - i have very little experience directly with the 4090 mics, so the book is still open.
