I had a mic stand break but the base of course is still fine. Is there a place that sells just the stand?
The one in question is a ProLine, but aren't the threads standardized? Could I get an On Stage or K&M microphone stand pole instead?
The "standard" outside tube is 7/8" - 27 TPI. You might be able to find a threading die from an industrial supplier.
You need to grind off the hard chrome on the outside first or you'll mess up your die. Good opportunity to add to your short stand inventory .The "standard" outside tube is 7/8" - 27 TPI. You might be able to find a threading die from an industrial supplier.
