A little thought experiment, that my particular brain cannot quite fathom.
Consider a plain cuboid ported enclosure having the driver plus a correctly dimensioned port mounted symmetrically one above the other on the front panel and capable of producing the desired response.
Consider now an infinitely thin and infinitely rigid divider running top to bottom dividing the enclosure in two in a vertical and front-to-rear plane, the divider continuing through to the port mouth, dividing it in two also, and also around the driver's magnet and basket. The only direct air path from one side of the enclosure to the other is between the basket and cone. The upshot is a common driver operating now into two enclosures and ports both exactly half the original size.
Will the frequency response be affected?
Stay safe All, Carl.
