Hi Everyone
I am kind of new here and after having built few vented enclosures for bass / midbass drivers, I decided to go forward and build Tapped Horn types in order to get the best of my RCF LF15N401 with this plan :
https://www.freespeakerplans.com/plans/14-plans/basscab/10-apache-h15 .
But before-hand, I have few questions in mind :
I am also open to any other "simpler" design that would give close results to this design, the idea here is to have an enclosure that give the most powerful SPL / DB for the minimum power needed.
Ex : https://www.gearclubdirect.com/rcf-passive-ip55-800w-15-neo-subwoofer/ ?
Here is the spec sheet of the driver : https://www.rcf.it/c/document_library/get_file?uuid=2f6242ce-9d1e-4cf4-b611-d85de1526836&groupId=20195
Here is a picture of the ported enclosures I have built for the record
Thank you in advance for your lights. BLESS
- Vibrations : I need to have my setup (turntables + mixer) diretly on the top of the enclosure : How will it goes with the bass vibrations ? Will I be able to operate everything smoothly or will it be unpracticable ? If too shaky, what would be a solution to have my setup on the enclosure or as close as possible ? I need to be ultra compact
- Plan Optimization : On the plan, it's written that many drivers are fittable, but I know that each driver has it's own characteristics, so on it's on enclosure size. How could I optimize this plan for the RCF LF15N401 and be sure I'm getting the best of the driver ?
- Wood type : Is it ok if I use MDF or I strictly need to use plywood ?
