Real Name Policy
Bennett Prescott
Just This Guy, You Know?
Staff member
Jan 10, 2011
10,858
39
48
40
Wallingford, CT
www.bennettprescott.com
You must have your real name set in your profile to post in this forum.
To do this, click here: http://www.soundforums.net/profile.php?do=editprofile
Then, update the field marked "Edit Real Name:". This will change your login to your real name. Unfortunately there is no better way to do this in vB... the one downside of this otherwise excellent software. The next time you log in you will therefore need to put your real name as entered for your user name, i.e. "Bennett Prescott". Spaces and other special characters seem to be OK, maximum length is 30 characters.
attachment.php
By real name I mean what someone might write on a letter to address it to you. If everyone calls you Ben, then "Ben Lastname" is fine, even if your mother calls you Benjamin. If a close friend would have to think to remember what your legal name is, then your nickname is fine. If you have used your middle name essentially your entire life because your first name is Clifford or something else ridiculous, that's fine too. Otherwise, indicate your nickname like Frank "Loogie" Zappa or similar if you like. "Frank Z." is not acceptable. "frankzappa" is discouraged.
Even if you use the name VCAMaster everywhere else on the Internet, you may not use it here.
