RF Combiners
Jordan Corona
2
Marble Falls, TX
What’s the best solution for combining 10 or more channels of wireless to antenna?
Sennheiser and Shure each have 8ch units, professional wireless’s largest combiner also /
seems to max out at 8ch.
Jordan Corona
2
Marble Falls, TX
Dude!
I love RF Venue stuff. Does the cascade set up work for combiners as well as distributors? My problem is that every combiner I can either supports 8 or 4 Txs, I need at least 10 out.
Jeffrey Knorr
Honorary PhD
4
Berwick, PA 18603
CobraSound.com
Check out https://www.minicircuits.com/ I'm using their products in both splitting and combining roles for Sennheiser receivers and IEM transmitters respectively. They work very well--just make sure that you specify the impedance and connectors that you need.
Jeff
Reactions: Riley Casey
Diogo Pereira
Barcelona, Spain
To combine 10 you need 3 RF Venue Distro (best bang of buck splitters). PM me if you need pricing.
Dude!
So... if we're talking about "transmitter combiners" and you need 10 INPUTS, you can consider:
1) using a passive combiner to combine two active combiners (8+4 for example).
Shure PA821 (8 input combiner) + PA421 (4 input combiner) combo will give you the 12 inputs you need and both have a passive combiner built-in the front of the unit. You will lose 3 dB (half-power) on each carrier, but hopefully you can compensate for that upfront with transmit power from the IEM units. What model of IEMs are you using?
2) Second option: use 2 transmit antennas. No passive power loss.
Hope this helps.
Cheers
