Las Vegas, NV, April 2019… Stage Tec, the Berlin-based manufacturer of professional audio technology, has received the label “SMPTE ST 2110 JT-NM Tested” for its XFIP/RIF67 NEXUS products at NAB. The JT-NM Tested program documents the extent to which products implement the ST 2110 standard. The results were presented at the NAB IP showcase. Stage Tec participated in the ST2110-30 audio test and the ST2022-7 test with its XFIP/RIF67 NEXUS products. The catalogue with the description of the full test procedures, the results and the participant list can be downloaded here: http://jt-nm.org/jt-nm_tested/.
“Stage Tec’s participation in the JT-NM Tested program was a complete success,” sums up René Harder, member of the Stage Tec management team responsible for innovation management. “The use of IP is becoming increasingly important in the industry. The need to ensure interoperability between devices from different manufacturers is therefore growing. The independent test results...
Continue reading...
