Now what the heck do I do?
My friend was poking it with the side of his drum key last night and got it out (now I can see what you mean, gently push in and twist...it was twisting far enough just not 'springing' out, it's good now).
So, next problem. Bought a new fuse, put it in, plugged the desk in, powered it up and ZAPSPARKwhispofsmoke Tripped the household circuit breaker. What on earth?! Checked the new fuse after that, it still has continuity!!! O.O
The only things that were different were that the cover on the bottom is currently off (but it's grounded elsewhere so that shouldn't be a problem should it?) And this fuse is ceramic...(guy at the shop said this would be more stable for audio gear...)
Now what the heck do I do? Not keen to plug it in and repeat the zap spark thing...
Edit to add; visual inspection of the circuit reveals a cooked resistor. So, if nothing else, I'll need to replace that before going on. But still, if anyone has any idea why it sparked....
Lisa,(weirdest thing, replacement fuse is intact.)
Bah! I want to know how to fix it (hence the jumping in .)
Yay!! :-DAs wide a field as electronics can be luckily the skills required to repair a regulated DC power supply are at the early and easy end of the spectrum.
original glass fuse on the left reads T1AL 250v. then what looks like a s in a box. replacement fuse on the right reads T1AH 250v
