Junior Varsity
Toilet shims....the answer to your problems.
<blockquote data-quote="Dick Rees" data-source="post: 5342" data-attributes="member: 16"><p>Got K&M fixed 15 degree tilters? Get thee over to Hardware Hank and buy a packet of hard nylon toilet shims. "Re-adjust" the stock angle to 10 degrees using a bench vise and a length of pipe, then drill holes the diameter of the K&M bolt in the shims. Place one above the bar and one below between the bar and the stock washer and.......PRESTO.</p><p></p><p>By rotating the shims you now have modded your tilters to set up at 5, 10 or 15 degrees with a simple adjustment requiring less than a minute.</p><p></p><p>Feel free to start the puns and "toilet humor".........</p><p></p><p>DR</p></blockquote><p></p>
[QUOTE="Dick Rees, post: 5342, member: 16"] Got K&M fixed 15 degree tilters? Get thee over to Hardware Hank and buy a packet of hard nylon toilet shims. "Re-adjust" the stock angle to 10 degrees using a bench vise and a length of pipe, then drill holes the diameter of the K&M bolt in the shims. Place one above the bar and one below between the bar and the stock washer and.......PRESTO. By rotating the shims you now have modded your tilters to set up at 5, 10 or 15 degrees with a simple adjustment requiring less than a minute. Feel free to start the puns and "toilet humor"......... DR [/QUOTE]
Junior Varsity
