I have A ps8-system with 2 ps8, 2 ls400, A ps8 controller, controlling A Camco q-power 6. Is it possible to link two ps10 to this system? Is that A good idea to expand the sound or will it be troubble because I have the ps8-controller?
Real world answer is yes you can do it but no it's not a good idea. The controller has the characteristics of the PS8 speakers which will be different from those of the PS10. Since the PS8 likely has more limited power handling and low frequency extension than the smaller PS8 you are less likely to damage the larger speakers the 10s will also not perform as they should. Try it at low levels before running at show level and note the differences between the PS10s and PS8s.
