Wing Ghost Screen issue
Douglas R. Allen
15
Maine USA
Should you ever notice your Wing touch screen changing or doing adjustments own its on you may have Ghost screen issue. It is a hardware issue. A test was added to see if there is an issue with your screen.
"""For user concerned about ghost touches.
A test mode was recently added. You can access it by holding down HOME and METERS while powering on the console.
The error should not develop over time so if it doesn’t happen now it shouldn’t happen later either.
It is a hardware error and can therefor not be fixed by a firmware update. Please contact your seller/distributor/service center for help.''''
People seem to be testing between an hour to overnight.
Just passing the information along in case someone may have the issue
Douglas R. Allen
