Wireless ethernet bridge?
TJ Cornish
Graduate
Jan 13, 2011
1,263
St. Paul, MN
I'm looking at getting some JBL SRX812Ps which have networkable DSP and programming. It would be really convenient if there was a way to make that wireless. Does anyone know of a small form factor wireless to wired Ethernet bridge that would be appropriate to hang on the back of a speaker like that? It would be great if it would be small enough to glue/screw/tie somehow onto the Ethercon connector.
I would power it via an IEC passthrough cable:
Anyone have a device they've liked?
Thanks!
Doug Johnson
41
2
8
Re: Wireless ethernet bridge?
I have a couple of these that I use when doing installs, http://www.amazon.com/TeckNet®-300M...1426252852&sr=1-2&keywords=wireless+router+ap . They have worked well and haven't given me any issues. For live shows I use these, http://www.amazon.com/EnGenius-Tech...UTF8&qid=1426253049&sr=1-14&keywords=engenius . They are rock solid. Given your use, I would be inclined to just make some cat5, signal line, power looms and run back to a single router/access point. You need to run wires to the speaker any way and adding a cat5 line to the loom shouldn't be cumbersome.
TJ Cornish
Graduate
Jan 13, 2011
1,263
St. Paul, MN
Thanks - the first box looks pretty cool. I'm not interested in a multi-cable loom. I don't always use the same length cables, and being able to grab whatever length XLR cable I need and take power from wherever I can makes more sense for how I work. My use is not primarily as main speakers, but as front fills, delay speakers, or monitor wedges as part of a larger system, so there isn't really a set configuration I could wire for.
Brian jojade
Senior
Jan 15, 2011
718
9
Wausau, WI
www.happymacshop.com
I'm a huge fan of the Apple Airport express. It's pretty compact, and has a built in power supply, so no stupid wall wart. Plus, with the audio out jack, you could feed music to the speaker wirelessly if you needed to.
