Yesterday I used a Yamaha TF5 and for some reason, the panning was not following the movement from left to right. Anybody had this problem? Is it a software issue?
Test it on scene zero to see if it does the same thing. If so then there is a problem with the console and it's time for a hard reset and perhaps a call to Yamaha. If not then you're doing something wrong and need to read the directions some more.It's on every channel. When I use the cue with the earphones you should be able to here the pan moving and it stays in place. Some channels are on the left some in the middle and so on. Can't pan at all but the pan in the screen moves.
