Quantcast
Results 1 to 14 of 14
Thread: Soundcraft mini Stagebox's
  1. #1
    Im looking for some info on the new stage box's from Soundcraft. Can you daisey chain two of the 16x8 versions to make a 32x16 on stage ? Do I have to run word clock also along with a cat5 cable ? What are the advantages/disadvantages of running optical as apposed to cat5 ?
    thanks
    -Brian
  2. #2
    Re: Soundcraft mini Stagebox's
    I'm wondering the exact same thing. Did you figure it out?
  3. #3
    They cannot be daisy-chained or linked. MADI is point-to-point only, not a network like Dante is.
    Of course if you have a console with multiple card slots, like the Performer, you could run a stagebox on each slot (with a MADI card installed of course).
    You do not need to run word clock with the Cat5 MADI; I am not 100% sure on optical MADI though.
    The cat5 MADI is a Soundcraft-only thing; it's not supported widely like the Optical or Coaxial MADI standards are.
    Advantage of cat5 MADI is mainly cheap cable but the downside is ~300 foot length limit.
    Advantage of optical MADI is mainly wider support (for other devices like recording cards) and longer cable runs (over 300 feet is no problem), but the cable is much more expensive.
    The Soundcraft mini stageboxes are shipping early May but can be ordered now.
    Concerts Unlimited LLC Website or Facebook
    Silas Pradetto on Facebook
    Visit the new Concert Cases Facebook page for all your custom case needs
    Dealer for: AKG, Allen & Heath, Alto, Antari, ART, Astatic, Audix, Behringer, CAD, CBI, Chauvet, Community, Crown, Danley, DB Technologies, Elation, Eminence, Fulcrum Acoustic, Irradiant, JBL, K&M, On Stage Stands, Powersoft, Presonus, Radial, RCF, Soundcraft, Ultrasone, Xilica, VTC, Yorkville
  4. #4
    Thank you for the great reply.
    I have another question though. On the Mini stagebox-32, it has 4 aes/ebu outputs. What can you do with that on a stage?
  5. #5
    Administrator David Karol's Avatar
    Join Date
    Jan 2011
    Location
    San Francisco, CA
    Posts
    1,138
    Blog Entries
    20
    Quote Originally Posted by Michael Parent View Post
    Send a digital signal straight into your DSP, and avoid an extra D/A, A/D conversion in your signal chain.
  6. #6
    I saw the Allen&Heath GLD stageboxes are daisychainable up to 2 GLD-AR84 on a 2412. Did you get some documentation from soundcraft to say that it's not possible on their side? I can't find any official in-depth doc on their mini-stageboxes...
    Thank you
  7. #7
    Quote Originally Posted by David Karol View Post
    Yes I know that. But my outputs won't get any DSP at this point. Say that I have 14 auxes to send (like the 14 on a SI mixer, coincidence?) and all I get is 8 analog and 8 digital. It gets somewhat pricey to buy a converter because I can't use all my auxes outputs.
  8. #8
    Run an analog drive snake...
    Sent from my XT907 using Tapatalk 2
  9. #9
    Thank you
    To clarify on the GLD... it's possible to deploy two AR84 boxes but only if one of them is connected directly to the console.
    Only one AR84 can daisy-chain from the 2412.
  10. #10
    [QUOTE=Silas Pradetto;49576]Run an analog drive snake...
    Can you send more info on this. I never heard of such a thing.
    Ok I got it, it's a regular analog snake... I always thought digital outputs cannot be connected to analog gear...
  11. #11
    Only one AR84 can be daisy chained from the AR2412, the other one has to connect directly to the expander port on the console. To get 40/20 on stage you'd need to run 2 Cat5 cables.
    Chris
  12. #12
    Quote Originally Posted by Silas Pradetto View Post
    or petition Soundcraft to make a 32x16 analog snake
  13. #13
    Regarding the MADI card, the literature says, "Both models (16 and 32) are supplied with the stagebox card installed, plus the corresponding card for an Si series console (Vi console MADI cards sold separately)".
    That looks like it means the MADI card for an Expression is included when you buy a mini stagebox. Does anyone know if this is in fact correct?
  14. #14
    Quote Originally Posted by Eric Valenzuela View Post
    Yes it is true.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
