Junior Varsity
01v96 with VNC/Remote SLOW
<blockquote data-quote="Bill Hinds" data-source="post: 3324" data-attributes="member: 1038"><p>Hello Guys,</p><p></p><p>I am hoping someone can help me out with this. I am running Studio Manager with our 01v96. Using a laptop connected to the 01v via usb cable, Belkin Router, tight VNC Server on the laptop and tablet is a Motion Computing with VNC Client. I get everything to connect properly and I have control and is just fine when there is not much going on BUT when the band starts (16 channels) playing the response time on the remote is so slow it is unusable. Meters lag, when I try to make an adjustment it is 3 seconds behind, etc. When I have play back music going (one channel) response time is fine.</p><p></p><p>I have used this setup in the past with no issues but with two difference. I was using a older gateway tablet instead of the Motions Tablet and the Laptop was an older Toshiba Satellite running XP. I would try my old setup but the older gateway basically died.</p><p></p><p>What do you think could be causing this? If it is the router I was thinking of getting something better but did not want to spend the $'s if that is not the issue. This router has been acceptable in the past.</p><p></p><p>Some other info.</p><p></p><p>Toshiba Satellite Laptop Running Windows 7 64bit</p><p>Tablet is running XP</p><p></p><p>Any help would be appreciated.</p><p></p><p>Thanks,</p><p></p><p>Bill</p></blockquote><p></p>
[QUOTE="Bill Hinds, post: 3324, member: 1038"] Hello Guys, I am hoping someone can help me out with this. I am running Studio Manager with our 01v96. Using a laptop connected to the 01v via usb cable, Belkin Router, tight VNC Server on the laptop and tablet is a Motion Computing with VNC Client. I get everything to connect properly and I have control and is just fine when there is not much going on BUT when the band starts (16 channels) playing the response time on the remote is so slow it is unusable. Meters lag, when I try to make an adjustment it is 3 seconds behind, etc. When I have play back music going (one channel) response time is fine. I have used this setup in the past with no issues but with two difference. I was using a older gateway tablet instead of the Motions Tablet and the Laptop was an older Toshiba Satellite running XP. I would try my old setup but the older gateway basically died. What do you think could be causing this? If it is the router I was thinking of getting something better but did not want to spend the $'s if that is not the issue. This router has been acceptable in the past. Some other info. Toshiba Satellite Laptop Running Windows 7 64bit Tablet is running XP Any help would be appreciated. Thanks, Bill [/QUOTE]
Junior Varsity
