Is there any issue with having 2 clearcom power supplies on the same partyline and powered on?
Sent from my iPhone
Sent from my iPhone
Sent from my iPhone
Like all current Clear-Com Party-Line power supplies, two or more units can be connected in parallel for increased system capacity or backup redundancy. Multiple units will automatically synchronize their response to power faults and overloads.
Apart from line termination, you also risk to make a ground loop.Is there any issue with having 2 clearcom power supplies on the same partyline and powered on?
Sent from my iPhone
I'm looking for redundancy, not isolation. Lifting Pin 1 (in case of ground loops) and checking termination should be all I need to do, correct?
If you're only concerned about redundancy then you can put both power supplies in the same location, and there won't be a risk of a ground loop.
However, if you have them both paralleled and one drops out how will you know that you've lost redundancy?
you might be better off with an A/B switch. you'll lose comms momentarily while you switch over, but you'll know right away to get the PSU fixed.
Jason
Wouldn't be that hard to rig up an automatic failover box if one were so inclined
