Nice job Timo!
anyway i can't see the skydrive things
don't have permissions
Got some questions... why a different slope for the lows hipass (12db/oct) in relation to the highs lowpass (24 db/oct),
I would even choose a 12 db slope on the high driver if it could take that but i had to use the 24db filter in order not to damage the high driver .
The reason for me to use a 12db hp filter : it gives me a larger overlap area (if aligned properly a larger addition area) and less group delay
that should result in a 180° phase mismatch, with more job to do with the allpass to align all... is this correct?
It should if i would use delay to align the system but with allpass filters i'm only delaying a specific part of the frequencies (the part off the phase slope that has a upwurth angle) to get the angles of the phase slope to match .
If i have to reverse polarity i will but only if i have to because the slope matches with a 180° phase difference .
did you try to align with delay and then fine tune with allpass? do you have screenshots? what approach you think is the best for a nice short IR result?
At the last jobs i did where i had the allpass filters available i tried to use as little delay as possible . On 1 job i had the allpass filters available but ended up using delay but this was due to the high driver being in front of the low & mid drivers of the system (this was a big line array loudspeaker from spain) . Sorry no usable screenshots available because of me not saving everything within sim3 .
The best result for a flat phase/tight impuls response for me is try to avoid using delay .
The other way to get a flat phase system is using FIR filters . This is something i can not do because i'm not able to calculate them and it's something i do not fully understand nor can i controll them . All-pass filters is something i can measure and controll so that's the way for me . Also fir filters will give me more latency in the system specialy if they are at lower frequencies so i do not mess with them .
thx a lot!
luigi.
