[FS] 2 Dbx driverack 260's
Re: 2 Dbx driverack 260's
Pictured attached for all interested parties. As you can see these are in great shape and only have the tiniest marks where the rack screws were. One still has the protective plastic on the screen. I use rack screws with rubber backing washers, so I bet that would wipe right off if you are that particular. Again, these were purchased new this past winter and have seen VERY little use. The both come with a factory box, manual, CD, db-9 and power cables. I will include shipping at the above quoted prices anywhere in the USA.
Tom,
Whats the difference between a 260 and driverack pa? Is there a notable sound quality change?
Al
I've used both and I think the 260 definitely has the edge on sound quality and control. The 260 also gives you more flexibility in setup and routing, and is also very easy to program via laptop using the driveware software. It's a great utilitarian DSP, we've gotten good use out of the half dozen or so we've owned.
If it helps sway anyone's decision, I'll drop the price for a single unit down to $500 shipped if you pay with check or money order.
