Junior Varsity
36mm / 1 7/16 inch speaker stand adapters
<blockquote data-quote="Mike Caldwell" data-source="post: 4025" data-attributes="member: 170"><p>Anyone know of a simple speaker stand adapter, sleeve what ever you want to call it that will take either 1 3/8 up to 1 7/16 / 36mm or take 1 1/2 down. I have some RCF 312's that the internal pole mount socket is too big for 1 3/8 and too small for 1 1/2 inch stands. It measures 1 7/16 or call it 36mm.</p><p></p><p>The local muffler shops can't reduce an 1 1/2 inch tube or expand the telescoping insert up, most they could do is take 1 1/2 inch and expand it. I going to check a couple fabricating shops that do tubing work. As a last resort I thinking of having a couple of inserts turned out of aluminum, one end would fit inside the 1 1/2 inch tube, with the other end turned slightly smaller to 1 7/16. That would replace the telescoping adapter that is supplied with the Ultimate stands. Gaff tape on the 1 3/8 tube would cut it either for this!</p></blockquote><p></p>
[QUOTE="Mike Caldwell, post: 4025, member: 170"] Anyone know of a simple speaker stand adapter, sleeve what ever you want to call it that will take either 1 3/8 up to 1 7/16 / 36mm or take 1 1/2 down. I have some RCF 312's that the internal pole mount socket is too big for 1 3/8 and too small for 1 1/2 inch stands. It measures 1 7/16 or call it 36mm. The local muffler shops can't reduce an 1 1/2 inch tube or expand the telescoping insert up, most they could do is take 1 1/2 inch and expand it. I going to check a couple fabricating shops that do tubing work. As a last resort I thinking of having a couple of inserts turned out of aluminum, one end would fit inside the 1 1/2 inch tube, with the other end turned slightly smaller to 1 7/16. That would replace the telescoping adapter that is supplied with the Ultimate stands. Gaff tape on the 1 3/8 tube would cut it either for this! [/QUOTE]
Junior Varsity
