Installs
70v System vs traditional...
<blockquote data-quote="Jason Hodges" data-source="post: 1979" data-attributes="member: 862"><p>Hopefully you guys can give a solid answer for this situation....</p><p> I am replacing a stereo system in a locker room. Its actually 2 rooms connected together. Each room is 30x30x15 cement walls and ceiling. Each room had 4 speakers with a volume control. This lead to a central receiver that controlled both rooms. This was a traditional 100v (?) system with 8 ohm speakers. The receiver died. Most of the speakers still work (6 out of 8).</p><p></p><p>So my de lima is to switch to a 70v system or use a traditional system. People have giving me insights on both systems and both sound good. I lingering questions is will a 70v system produce enough sound for a locker room setting? Or should I stay with a traditional system. If so can you point me in the right direction as far as components and brands that are quality?</p><p></p><p>Thanks so much for your time and help!!</p></blockquote><p></p>
[QUOTE="Jason Hodges, post: 1979, member: 862"] Hopefully you guys can give a solid answer for this situation.... I am replacing a stereo system in a locker room. Its actually 2 rooms connected together. Each room is 30x30x15 cement walls and ceiling. Each room had 4 speakers with a volume control. This lead to a central receiver that controlled both rooms. This was a traditional 100v (?) system with 8 ohm speakers. The receiver died. Most of the speakers still work (6 out of 8). So my de lima is to switch to a 70v system or use a traditional system. People have giving me insights on both systems and both sound good. I lingering questions is will a 70v system produce enough sound for a locker room setting? Or should I stay with a traditional system. If so can you point me in the right direction as far as components and brands that are quality? Thanks so much for your time and help!! [/QUOTE]
Installs
