Installs
a 70 volt mind teaser
<blockquote data-quote="terry walsh" data-source="post: 4740" data-attributes="member: 1795"><p>I have a situation that is not covered in any searches. Six 8 ohm outdoor speakers, transformers cannot be added to each speaker because they are outdoor rock speakers. So there is a 100watt transformer indoors, with 70 volt in and 8 or 16 ohm on the output. Is impedance a factor ( put 4 in parallel , 2 in parallel and combine in series to achieve the 4 at 8 ohms and 2 at 4 ohms ) or just connect all 6 in parallel.</p></blockquote><p></p>
[QUOTE="terry walsh, post: 4740, member: 1795"] I have a situation that is not covered in any searches. Six 8 ohm outdoor speakers, transformers cannot be added to each speaker because they are outdoor rock speakers. So there is a 100watt transformer indoors, with 70 volt in and 8 or 16 ohm on the output. Is impedance a factor ( put 4 in parallel , 2 in parallel and combine in series to achieve the 4 at 8 ohms and 2 at 4 ohms ) or just connect all 6 in parallel. [/QUOTE]
Installs
