Junior Varsity
A&H GL2200 repair; right channel drops volume.
<blockquote data-quote="Matt Vivlamore" data-source="post: 5527" data-attributes="member: 33"><p>I have a GL2200 and the right channel (main out) will randomly drop in volume. If I wiggle the XLR connector, the volume will come back up for a couple seconds.</p><p></p><p>Any ideals? I have hit the solder joints with heat. The XLR cable into the board is a randomly pulled one from the case.</p></blockquote><p></p>
[QUOTE="Matt Vivlamore, post: 5527, member: 33"] I have a GL2200 and the right channel (main out) will randomly drop in volume. If I wiggle the XLR connector, the volume will come back up for a couple seconds. Any ideals? I have hit the solder joints with heat. The XLR cable into the board is a randomly pulled one from the case. [/QUOTE]
Junior Varsity
