I have an ADA8000 where the 'input' optical port got slightly damaged. It works, but the connector isn't as secure as it is supposed to be. I primarily use the ADA8000 for OUTPUTS, so this is a major point of failure for me. If you need an ADA8000 for INPUTS, the 'output' optical port is fine...and this would be perfect for you.
So, if you have an ADA8000 with both optical ports good, I'll take it, and give you some cash plus this one.
silas@concertsunlimited.com / 860-337-1040 / PM
My goal is simply to get a properly functioning ADA8000. If there's something else you need, like cash or product, let me know!
