Aes a/d-d/a
Jan 19, 2011
1,017
64
48
44
Oslo, Norway, Norway
drbentsen.no
I need to expand inputs/outputs on a piece of gear and I only have the AES port left.
I'm not familiar in the wold of AES converters, basically I need 8 analog lines to AES and 8 channels of AES (4 stereo) to analog. AES connections on a Dsub is an advantage, but not necessary.
Any units in particular I should look at?
Andrew hit the nail on the head.
There's also an older piece that Lucid/Symetrix made called the ADA8824. It was also available with an optional lightpipe card. You may be able to find this box used for relatively low cost.
Re: Aes a/d-d/a
I recently used a Yamaha AD8-HR for the input side of your need. Since you also need output conversion, the RME unit referenced above would be my suggestion.
