[FS] Allen & Heath GL2400 24x4x2 Mixer with Road Case in MA
Rob Bernstein
66
Framingham, MA
This is a local (New England) pickup/delivery deal. I can meet someone within 60 miles of Boston to deliver.
Allen & Heath GL2400 24x4x2 Mixer with Road Case, dust cover, and 2 LED lamps.
A true classic for live mixing, this board has served me well mixing many shows. Board is 100% functional, and includes some nice extras like the dust cover and LED Lamps.
The mic pre's and EQ on this board sound phenomenal. I am downsizing and keeping my 16-channel Allen & Heath board.
Also includes the manual. If the ad is up, the mixer is still available.
I would be willing to meet someone within a reasonable distance to MetroWest MA to deliver the console.
$1200 includes everything.
GL2400 Dual-Function Live Sound Mixer
GL2400 is a compact, dual function, LR, Mono sum, 4 group, 6 aux, 7x4 matrix console. Frame sizes range from 16 to 40 channels, including 2 dual stereo channels.
The GL2400 is a mixing classic, industry standard in venues and hire stockists across the globe. The ultimate 4 group dual- function mixer, the GL2400 is designed for the latest in modern engineering techniques, and every detail in this uniquely capable small footprint mixer has been carefully thought out to provide the very best mixing experience.
• 24 channels
• LR and M main outputs
• 4 Audio groups with pan control
• 6 Auxiliary sends with per-channel pre/post fader switching
• 2 stereo channels, each with mic and dual stereo line inputs
• 7x4 Matrix
• Proper dual functionality for FoH and/or Monitor mixing
• M can be configured as LR sum, Wedge, or Aux-Fed Sub or C master
• Recording capable with channel direct outputs
• Matrix external inputs with level trims and common input capability
• Stereo channel line inputs can be independently routed to LR
• Stereo channel mic input breakpoints for cross patching into matrix
• Responsive 4 band, 2 sweep EQ
• 100Hz channel high pass filters
• Individual phantom power and polarity switching
• Dedicated channel, master and stereo monitor meters
• Internal jumper plugs for pre/post-EQ aux, direct out and other options • Mutes, meters and AFL on all fader masters
• Assignable talkback
• 1kHz oscillator and pink noise generator
• 2-track monitoring and replay to LR
• Headphones and local monitor outputs
• 4-pin XLR lamp sockets
• Electronically balanced XLR outputs with +26dBu drive capability
• Preamp 74dB range with +34dBu input capability for mic or line
• Ultra low noise mix head amp design
