So, I've been a long-time Crown Itech and Itech HD user but lately I'm getting a bit annoyed with both Crown's amps and the other big players' amps - Powersoft and Lab.Gruppen.
The Goal:
Crown Itech HD:
Lab.Gruppen PLM:
Powersoft K series +DSP:
Summary:
None of the above options offer what I want, with the main issues being networked audio and FIR compatibility. Considering there are a ton of companies that are deploying scores of amplifiers at each show, I'm trying to figure out why the network part of this equation has not been really addressed. Is everyone afraid of using networked audio? Is it too complicated for the average tech or company to understand? Why is it any more difficult than distributing 100 channels of analog audio? (I think it's vastly easier...).
Finally, why can't the Lab PLM FIR function actually be useful?
I wonder if anyone has any other ideas or suggestions for amps to look at?
The Goal:
- To be able to distribute audio on an IP network to all my amps, with a relatively simple way to input the signal into the network. This would be either an analog/AES to network converter box, an existing MY card, or cards for other consoles.
- The ability to process FIR for the major industry players, including Fulcrum Acoustic, EAW Graybox, and Vertec V5.
- Very good power/size ratio, preferably 4 channels in 2U, with a minimum of 2000 watts/channel at 4 ohms.
- Good control software for DSP settings and audio routing.
- Good manufacturer support and pricing.
Crown Itech HD:
- My issues with the Itech HDs include a completely antiquated, high-latency networked audio protocol, Cobranet. I was going to use this live, but many things prevented it. The network is supposedly latency and sample rate adjustable, but it's dependent on the compatibility of all the devices on the network. I couldn't get it to do anything different than 48k at 5.33ms latency. Unfortunately, JBL Vertec V5 settings require 96k sample rate, and with Cobranet working only at 48k, I can't use V5 on a Cobranet network. JBL's solution is to 'use AES'. That's not a solution. Additionally, nothing seems to really work with Cobranet that well, and configuring it in general is a major task.
- Itech HD, according to EAW, cannot process their graybox tunings.
- Other than the new 4x3500HD, the amps are not very power dense, being 2 channels in 2U. They do offer the power I want, though.
- System Architect is normally fantastic, but lately, I've had other major issues loading Vertec V5 settings into the HDs with the newest firmware. For some reason, the presets only load about 10% of the time. The rest of the time either the preset half loads and there are no controls on the control screens (very, very odd), or the presets only appear in name and there is no actual DSP happening - the amp is wide open. Trying to go back to my old amp device files does not fix the problem, usually, and has caused me some major headaches at recent shows.
- Manufacturer support of the Itech line seems to be very good and the pricing is also very good.
Lab.Gruppen PLM:
- So, Lab.Gruppen supports Dante, one of the nicest networked audio protocols. No complaints there, the amps even include an integral switch so an external switch isn't needed for each rack.
- PLM can only process FIR for EAW's graybox tunings, and when doing so is very limited with input options.
- Good power ratings and excellent power density.
- The Lake software has always been a mystery to me, anytime I see someone using it I'm baffled, and many tell me that it's a pain to use.
- No idea about their support or pricing.
- Powersoft does not support any networked audio protocol other than the proprietary KAESOP thing they do. This runs a couple AES3 lines down the unused pairs of a 100Mbps network connection to form a ring network. That's all fine and dandy, but I run gig everywhere, which uses all 4 pairs, and probably won't appreciate a non-Ethernet signal being present.
- Powersoft can process FIR for everything except Vertec V5. JBL won't likely ever make V5 publicly accessible, so this is as good as it's going to get.
- K series are probably the smallest and lightest amps out of all of the options, with tons of power.
- Armonia is excellent from what I've been told and in my limited experience.
- Manufacturer support gets mixed reviews from people I've talked to, pricing is very high compared to other options, but you have to pay the most for the best, right?
Summary:
