Amp Tests (1 of 2)
Langston Holland
222
Pensacola
I pulled this over from the old PSW forum as background to an upcoming SpeakerPower amp module post.
Purpose:
My recent upgrade to the Danley TH118 subs has motivated me to look into larger amplifiers than the PL380 that has been perfect for the TH115's. I've also been underpowering the low passband of my KF730 boxes on the order of 3dB. I've justified this mentally because the low passband only covers 90Hz to 200Hz and the fact that I overlap the early part of this spectrum with subs. Now I'm going to drive those hungry 10" drivers to their limits. The KF730's are 16Ω boxes and the series pair of woofers is rated for 700 watts continuous, thus 1,400 watts "program" per box. A daisy chain of (4) to (6) of those boxes demands an amp that effectively didn't exist when the KF730 first came out. That, boys and girls, is not the case anymore.
The net result of the amp upgrade will be approx. 3dB more output from the same loudspeaker arrays from 200Hz downward. Same truck pack, same weight, same size, but more rig for the gigs. Just need to pony up around $10k (assuming sales of my existing amps) and I’m in. Is 3dB under 200Hz worth 10 grand for my (24) KF730’s and (8) TH118’s? Heck yes.
The higher frequencies are powered to their program ratings already with an amp that I've yet to find an equal to sonically. On that note, I’m going to add a fair amount of subjective commentary in this review that I used to shy from. I’m over it. Class D and the variants I’ve heard are not ready for critical HF reproduction yet. There, I said it - and it’s a fact unless you’re deaf, don’t care, think MP3 is good, or are trying to earn a living in this business. :)
Measurement Setup:
Room temperature 20C, voltages at the input and output of the amps were monitored with a Fluke 192C Scopemeter that has fully isolated inputs. Sine waves in various flavors were used for all tests. Long-term tests were done with 500ms on / 500ms off steps with distortion curves monitored via the amazing STEPS module in the ARTA measurement suite. Benchmark DAC1 and ADC1 converters with instrument grade +30dBu I/O capacity were optically connected to my MacBook Pro running XP in Bootcamp. A 21dB pad was used to feed the input of the ADC1 for a 51dBu maximum input capability. At the 4Ω resistive loads I placed on both channels of each amp in the test, this allows a maximum level of 18,904 watts to be measured cleanly. My new SuperBucket™ was used to take the heat. This thing presents (2) 4Ω loads with 14,400 watts long-term dissipation and peaks numerically similar to the national debt. You can also use banana plug jumpers to configure single 8Ω and 2Ω loads at double the wattage, assuming the jumpers survive.
SuperBucket
Measurement Theory:
Everybody and their mother have different ideas about how to best measure the performance of an amplifier. Some folks think the old fashioned way of feeding continuous sines is the deal because they apparently use their amps to arc weld during the middle of the week. On the plus side, you’ll get absolutely comparable results from every manufacturer, on the down side those results are not very meaningful for our application. My use of 500ms on / 500ms off sine steps yield effectively identical results as continuous sines in my experience and this is included. Since I use amps for powering loudspeakers with music, I prefer using shorter lengths of sines that approximate musical behavior as much as possible so I can have more meaningful metrics for the intended application. That's where the rub is – just what kind of stimulus comprises the most meaningful metric? For some reason folks keep looking for a _single_ metric to describe amp power, but I think that's a recipe for failure. In our application there is a long-term load as well as much, much higher momentary peaks that need to pass cleanly up to the point where the loudspeaker system begins to sound bad or fails. Those two thresholds are separated by about 6dB of voltage and 20dB of attitude. I've included both long-term and short-term tests in a way that makes the most sense to me. As of today. And it’s my party so I can do what I want. :) I’d love contrasting views as always.
Take a trip around the block and you'll notice that Lab Gruppen and Yamaha/NEXO, to name two, are measuring their amps in ways that attempt to account for the behavior of music as opposed to the behavior of welding machines. Both use sines to allow distortion measurement, which is critical. Lab uses a 33ms on / 66ms off step which seems quite reasonable as a single metric, especially at lower and mid frequencies. It might be a little severe (long) for the higher frequencies, but it keeps things consistent, repeatable and logical. Yamaha/NEXO uses a 20ms on / 500ms off step and only measures the last sine wave in the 20ms burst, and that at 1kHz apparently. This probably yields higher power ratings than reasonable and certainly shouldn’t be the only metric considered.
There's a guy named Don Keele that I've been following since the 80's that has contributed much to the loudspeaker industry, and by extension, the amplifiers that power them. The logic behind his attempts to measure both gizmos in a way that simulates actual usage makes sense to me and correlates with my testing and listening efforts, particularly as applied to limiter settings. As a side point, I think advanced limiter topologies that simultaneously deal with long-term heating and peak mechanical issues of loudspeakers in a sonically pleasing way are the next area of serious improvement in the quest for high SPL and good sound. Driver design will need to go hand-in-hand with this. NEXO is a forerunner here.
So what about Keele's short-term tests? Read Shaped Tone Bursts beginning on pg. 6. The earlier pages are an important intro.
Want his stimuli and have time to wait for 300MB? Click here if you dare. I neutralized a very expensive amplifier that was supposed to go to a little outfit that rhymes with “hair” after I was done with it. I wasn't careful enough with the 20Hz tone burst. Whoops.
Bottom line from Keele? From a post he made last November on the SAC list: "What we need is that 100 Watt continuous power amp that can pass 10 kW peaks for short periods of time."
I've had to chew on this concept for years to appreciate it, but I'm convinced he's right and my tests show more than a few amp manufacturers are convinced as well and are building amps accordingly. According to the needs of music instead of welding, imagine that.
Continued on Amp Tests (2 of 2) since this forum won't allow over 10k characters per post.
Amp Tests (2 of 2)
The Players:
Camco Vortex 6
Alluded to earlier, this is simply the best sounding professional amplifier I've ever heard. It's a class H design and somehow manages to reveal the most subtle details in high-end recordings with earphone clarity over (excellent) loudspeakers. To date I've yet to hear a class D variant (including the following amps) that can present the width and depth of a recording anywhere near as well. I have no idea why this is the case - no measurements I've ever made are conclusive. The flatter transfer function certainly doesn't hurt, but it's more than that. Full output at 120v 30 amps works perfectly, no need for the 208/240v model unless it’s more convenient for where you live.
QSC PL380
One of the best bang for the buck ratios on the planet. My (9) PL380's have been rock solid for several years. They are also one of the better sounding class D amps if you have to use one in the mid/high region. Like the Camco, full output at 120v 30 amps works perfectly, no need for the 208/240v model.
Powersoft K10
Oh my - this beast is ready for your welding rods and sine waves masquerading as music. One rack space of pure attitude - it's squirrel fans will go into overdrive if necessary, much like the old Crest 9001's, but this amp will just keep belting out continuous power unlike any amp I've ever come across. It also is solid on the Keele short-term tests. The amp is very well designed and feels as solid as it runs. Very logical layout and very efficient with power, will accept any voltage on earth and do sine waves all night long (trance, electronica, whatever). Optional DSP card available with FIR filtering, but not on the order of either the Crown HD or Lab PLM series. Quite good nevertheless - you can download the software for your PC and see if it fits your needs. Sound is much better than average for class D - about equal with the PL380, though a more forward sounding midrange. You obviously want 208/240v with this amp if you're going to use its full capacity.
Crown IT5000HD, IT9000HD and IT12000HD
The processing in these things simply rocks. Very steep and well-designed FIR filters, plenty of all-pass and parametric EQ filters. Nice average and peak limiter facilities. The software interface to the ITech amps is probably the best I've ever seen, Crown works very hard at this and releases updates frequently. I noticed earlier this year that the 2nd order all-pass filters weren't working and Crown had it fixed in less than a week - wow. It also made me wonder why I was the first to notice this since they’ve been out for a while... The software makes for very nice multiple amp management in larger company or install environments. The sound is greatly improved from my previous experience with the non-HD models. My guess is that it's due to the processing upgrade since the amps measure fairly similarly. I prefer the sound of the other amps in this test in the mid/highs when ignoring the processing, but you shouldn’t do that. I designed FIR filtered, flat-phase presets for Troy’s KF730’s to mimic what I’ve done with the Dolby Lake processor and was amazed at how good the net result was. The limiters sounded good too. I noticed a similar result when doing listening tests with the Lab PLM20000Q with internal processing vs. the FP14000 fed by a DLP. Interesting. Reliability reports are good with the HD series. The ITech's have always been good at making power and these amps are no exception, but it’s silly that they increased the numbers in their model numbers – output has not increased as far as I can tell. Though I don't report it here, short-term output into 2Ω’s will surprise you with either the older or newer ITech’s. You think this is a 4Ω only amp? Nope. It shows a similar increase in output into 2Ω’s that you see in typical amps as long as you don't ask it to do so for un-musically long periods of time. Still, voltage is king and is what SPL is made out of and you should stick to a nominal 4Ω’s regardless of amp IMO. The ITech’s play nicely with others due to worldwide voltage and PFC.
If you push these amps to their limits, you're going to want to feed the 9000 and 12000 with 208/240v. At 120v even at 30 amps, both these amps "groan" when under load. That kind of vibration can't be good in the long run. At the 240v feed they got during my measurements, they were nearly silent other than fan noise, which can get up into the Crest 9001 range. The 5000 is happy with 120v 30 amps into anything that will ever happen in practice, though it did want 240v for continuous sine testing.
Lab Gruppen FP14000
I'm buying (4) of these as a result of these tests. Their output to size, weight, sonics, warranty and cost is a winner. These amps are not auto-ranging, you have to choose either 120v or 208/240v - the latter is the only thing that makes sense given the horsepower involved. This amp is all about allowing the peaks of music to get through without clipping as their testing method indicates. It has both hard (lows and subs) and soft (mids and highs) limiting available as well as several cool protection circuits with a light show on the front panel. I made all the pretty lights come on without letting the smoke out. Too bad they make you buy a thousand dollar gizmo to connect your PC to the amp to monitor its behavior - they should nix that thing and its cost and allow you to connect your computer directly to the amp(s). Maybe the smaller Labs sound better in the mid/highs, but this amp showed its class D heritage in my listening tests, which nixed my thought of replacing the Camco's with a Lab on the mid/highs. Still, this amp is probably the best sounding class D amp I've heard.
Long-term Measurements:
Though I expected this to be boring, I accidentally learned some interesting stuff here about design philosophy between the various manufacturers. All have made reasonable compromises in trying to skin the cat of high output without damaging itself or the stuff at the other end of the loudspeaker cable when operated by a bunch of lunatics.
Each of the below show a reference measurement of magnitude and phase at 50 watts and at about 1dB beyond their maximum output capability with both channels driven into 4Ω. Do not freak out about the max power traces, I could have backed off a hair and made them all pretty, but that wouldn’t have been very helpful, would it? Plus I would have missed out on the flames from some of the manufacturers – and what fun would that be? Actually, I learn from those as well and look forward to it. Be sure to read the caption at the bottom of each graphic for details.
Camco Vortex 6 (low level and 1dB beyond max)
QSC PL380 (low level and 1dB beyond max)
Powersoft K10 (low level and max)
Lab Gruppen FP14000 (low level and 1dB beyond max)
Crown ITech HD (low level)
Crown ITech HD (1dB beyond max)
Short-term Measurements:
This is really interesting.
The following scope traces are from the FP14000 to demonstrate how I made these measurements. The scope is used to determine the point at which the shaped tone burst begins to deform and plotted with the input signal scaled to for reference. The red trace is the input signal and the blue trace is the output at the point where I judged it to be the maximum. I lost the 100Hz measurement like a dummy, and I’m too lazy to do the measurement again, but it’s immaterial. One thing you’ll notice is at the higher frequencies, the output trace is late to the party – a simple measurement of phase lag as predicted by the long-term STEPS trace. The scope's phase calculations agreed with STEPS. I think I’m getting the hang of this. :)
FP14000 Shaped Tone Burst Measurements
And now, ladies and gents… These numbers are per channel in stereo mode into 4Ω. They would have been higher at 2Ω, though voltage and the SPL from your loudspeakers would be lower. Chew on that. I hate this whole watts thing – just did it for the peanut gallery – next time it’s volts like God intended. :)
The Data
The Picture
Re: Amp Tests (1 of 2)
Very informative. I too like Don Keele's test for short term power. It is repeatable and correllates well to bass drum heavy music. Thump thump thump.
For the folks doing music like dub step, trance, reggae etc, a long term power test would be an interesting addition to what you have done. Dub step in particular seems to be near constant LF sine waves.
By long term power test, I don't mean hours, but a musically significant long term like more than 2-3 seconds up to 1-2 minutes. I think all the amps you have mentioned have limiters that cut back after a few seconds to keep breakers from blowing. So for instance if the amp has a 30A breaker, it may pull 50A for a few seconds before throttleing back output to where the mains draw is 30A. The power the amp will then deliver long term is limited by how efficient the amp is and how well it utilizes the power out of the wall.
The FP 14000, from it's data sheet, at 30A mains input delivers 1266W to the load and dissipates 1012 watts as heat. This is about 55% efficiency.
In comparison, under the same conditions the SpeakerPower SP1-4000 delivers over 2000W to the load since it is over 90% efficient.
I don't know about the other amps on your list since these specs are hard to come by. But since you have all the amps.....
Re: Amp Tests (2 of 2)
Lab Gruppen FP14000
Maybe because it's not a true class D amp ;-) I actually wrote to Lab a while back to get clarification of their "class TD" topology, and it was different than what I thought. The actual output stages are, in fact, class AB. The class D section only supplies power to the output devices, a "class D tracking power supply" if you will. IOW, they're using a relatively inexpensive class D circuit design to track the input audio signal and feed only the amount of power to the output devices required to drive the load. The power supply is a SMPS design which powers the class D circuit, which then drives the output circuity. Pretty ingenious really. You can make a very high output amplifier that's very lightweight and not have to give up the sonic benefits of a class AB amp. And the complexity of the class D circuit filter doesn't need to be that great since it's only delivering varying rail power instead of actual audio. I can see why these are popular. But they ain't cheap!
Greg
Amp designers wouldn't mind a thermal duty cycle test, to draw a line in the sand. i gave this a lot of though when Bink was doing his big power amp test exercise several years ago. One unintended consequence of a definitive duty cycle test is that amp designers would then target their amps to improve upon that publishable number.
The catch 22 is that music is not very neat as a test signal. I believe we are far enough along with digital recording technology to generate definitive test files (that could be looped) that would be representative of different musical genre, and could be repeatable enough to do reliable comparisons between amp platforms.
It doesn't even matter what these samples are exactly, as long as they are published so everybody can repeat the tests with identical stimulus.
Most amp designers I know, also used some select recordings as part of their design vetting. Standardizing this could get us one step closer to comparable numbers. So Langston could do something else with his spare time.
I'm not sure if that is wrong, or just awkward, but class D and switch-mode are two ways of saying the same thing (saturated power devices). In fact many class D power amps liberally borrowed from earlier switching power supply technology. The main difference is class D audio amps had to be made faster, lower noise, and lower source impedance (not to mention capable of sinking and sourcing current).
Greg
Clever perhaps, ingenious not so much (IMO). I think yamaha did a variation on this in some cheap power amps and powered mixer modules some time ago. IIRC the Yamaha uses bipolar devices for their switching supply and was marginal for output current over time at 2 ohms, but they may have improved it with later generations. For MI it worked well and saved on heat sink and transformer size.
From a theoretical or engineering perspective class AB is not some gold standard for audio amplifiers (in fact there are good and bad implementations of all topologies), and this hybrid approach is effectively wasting power in that extra class A/B stage used to filter out switching noise, etc**. While they save some on heat sinks, and secondary breakdown (VxA) issues with bipolar output devices. That class AB output stage has to handle the full drive current which is still relatively heavy lifting for bipolar devices. It is nice that they can use proven mature technology in the output stage where the rubber meets the road (class D screws up in different ways and involves a learning curve).
IMO as switching devices get faster, (and higher power) there is no (good) reason why a pure class D can not be made as good as the best analog or hybrid amplifier, and save that extra power wasted and extra cost of using that superfluous class AB stage. I am aware of a well respected lower power class D platform (Hypex). I haven't personally bench tested or experienced the current crop of high power sound reinforcement class D so won't opine one way or the other.
I will not argue theory over real world results. LG make amps that sound good and are relatively efficient, so that should be good enough. If it sounds good it is good... if it doesn't it ain't.
** I designed a small amp with a tracking supply back in the '80s and this isn't trivial. if you make the rail fast, it couples through the miller capacitance of the output devices and causes distortion, if you make the rail too slow you need to provide too much safety margin to prevent the amp outrunning the rail at HF and lose efficiency.. not trivial. Knowing how hard this is to do I am impressed by how well they did. I would be even more impressed by pure class D.
As far as clever & ingenious or not, I suppose I should leave that one up to you 'clever & ingenious' types to decide JR ;)
Greg
No worries, it's cool that you grok the design enough to talk about it.
Our different subjective opinions about the approach are just opinions colored by our different perspectives.
It takes a certain amount of genius and hard work to make any big amp work well, in the real world, making loud sounds and they deserve much credit for that.
Amps just like consoles are simple in concept, difficult in execution... lots of little things that may not be obvious from glancing as a schematic.
Marketers and customers like a hook they can grasp to credit for good/bad performance. It's hard to get excited by "they did a good job with all the details", but that's pretty much what I believe they did.
The Players:
Langston,
Wonderful review of these amps. Although it wasn't exactly what I wanted to hear about my iTechHD's! Could you elaborate more on this "groan when under load". I had planned on racking three 9000/1200's together with fed by L21-30 distro at 120V. Also planned on running up to 4 TH-118s off a 12000 (which would be under the program for those, therefor "heavy load"). Now you have me looking for 240v distros and looking into my venue's power situations or a new amp selection!
-Ian
Hi Ian:
I don't think you're going to have the slightest problem with the ITech groaning with that load and a 120v supply. My tests used a massive 4Ω resistor and sine waves to induce that kind of vibration from the amps' power supplies. A sine wave has a 3dB difference between its average and peak. Lab Gruppen's engineers did a wonderful study recently that they discussed at InfoComm this year that measured the crest factors all four passbands of the amp outputs at several major concerts and they found that 15dB was about worst case. This is consistent with previously reported studies, but it was fascinating to see their plots on a per passband basis with time on the X axis.
What does this mean? In reference to your question it means my test setup was insanely harsh relative to what we actually experience in live sound work. We have (3) variables here:
1. Output level. It's reasonable to assume worst case: the amp clip lights flashing the entire set.
2. Output crest factor. It's not reasonable to assume 3dB continuous sine waves. The amps' power supplies will have a great deal more down time than in my tests.
3. Output load. It's not reasonable to assume a flat 4Ω impedance that the amps will be forced to deliver power to. I don't have a TH118 impedance curve handy, but it's likely to be very similar to the 4Ω version of the TH115. The blue circles are the only places that the amp will see anything approaching 4Ω's (the heavy black horizontal line). The amp will be delivering very little power to the remainder of the passband, thus your power supply will be loafing compared to what my tests required of it.
You might devise your own test that would still be much worse than real world by making a high power 4Ω resistor with (3) 4,500 watt 240v water heater elements wired in parallel and submerged in a bucket of water. Instead of a sine wave, bring out your worst-case music samples and push the amp into hard limiting. Make sure you have the processing and limiters set for TH118 use. Bet it'll be quiet other than fans.
Bottom line? I'd try to feed a large amp 208v/240v whenever practical, but wouldn't fret about it - unless it's paired with a sub with (4) 21" drivers intended to cover 2,000 people at a rave. :)
Hi Ian:
I assume this 15dB crest factor is measured on a well powered system with plenty of head room, and averaged over a decent timebase. Short term intervals can experience events of significantly lower crest factor, while still not approaching that sinewave's 3dB without severe clipping.
High power burst testing is a very severe version of reality and fair to characterize how the amps will behave during brief high energy events, not for gauging longer term mains current draw or long term cooling load on amps. There the 15dB figure is probably more appropriate.
