Analog to Digital mixer recomendation
Dinesh Mani
2
I have an Allen & heath PA 12 analog mixer which has built in FX. I am in the process of upgrading this and am wondering if i should move to one of the digital mixers (Soundcraft Expressions, Allen and Heath QU-16/QU-24, Presonus Studio Live AI series ... etc) or should i just upgrade to a more high quality analog mixer like Midas Venice F/U series or the latest MixWizard WZ4 series. I will not need more than 16 but could use 24 channels for future needs.
What would you all recommend and why. My only fear about going the digital mixer route is the learning curve and the reliability that an analog board offers.
Thanks for you suggestions.
Re: Analog to Digital mixer recomendation
Unless I'd have very special needs I'd opt for a digital mixer.
While there is a learning curve you should grqsp the basics pretty quickly and then you can ease in onto the more complicated stuff within a resonable time.
All mixers above are great (you forgot about the x32 ;-) and it all comes down to prefered workflow and needs...
If you might want to expand the X 32 may be the only option in the price range.
If you can get to 5k you should consider the Midas M32. It is the Pro version of the X32 and will have you never looking back.
the X32 is no slouch but if you are doing rentals the Midas puts you closer to the bank.
How many shows have you mixed on each one?
Mac
Mac
Trick question ;)
I am curious as to how different the sound quality will be in a blind test. Will mic pre's and 96Khz sampling be enough to make an audible difference? If so, will it make $2500.00 difference? After all, one could purchase two X32's for the price of a single M32.
Trick question ;)
Not a trick question at all and delivered without snark.
Mac
the mix flow is (oops! Will be) the same for both - download the xedit app from behringer and see if this aspect suits.
The differences are the preamps, future 96k possibility,motorised fader type (better), looks and physical build quality (oh and logo).
Mr. Kerr's observation went over your head so fast we watched your hair move.
Trick question ;)
Possible future 96kHz sampling, 48kHz for now. But the faders and case are also different.
Mac
Easy - I have about 20 shows and 5 studio sessions on my X32. The M32 is not out yet but will be soon. It is $2k more and if it would have been released at the same time I would have bought it instead for the "Midas" alone. It looks better and has better faders. Mic pres on the X32 do sound good so I am not sure how much bang for the buck the true Midas pres will bring to the table.
I can only speak to my experience - MixWiz to a Presonus SI 16.0.2 -
I found the transition to be very easy.
There are no layers to understand and navigate.
I found it to be very "analog like" - you do need to adjust your workflow - other than faders, everything else is done one channel at a time - can't quickly scan the board to see relative settings.
Lots and lots the Mixwiz did not have. Gates, Compressors, graphs, scene recall, etc. Still love my MixWiz btw.
Presonus includes a lot of instrument/vocal profiles which can get the show set up and close quite quickly, even for someone relatively new to the board. This cuts the learning curve down considerably. Most of the profiles sound pretty good. Some non-combat time on the mixer will actually be a "training tool" to introduce you to how their filters, gate, compressor, etc settings work together.
Custom profiles can be saved easily. Entire board "scenes" can be saved for quick use later.
Metering is very thorough. All the "normal" digital goodies right there on top.
Software and support has been at least adequate. I do get the feeling the original series of mixers are completely developed (read orphaned).
PITAs:
No automated faders. Really not necessary as everything is one one layer - but when using computer/IPad control, it sure would be a nice to have.
No recallable preamps. I'll treat it as fact here. Lots of value discussion on the QSC thread on the pros and cons of the need vs utility.
No offline editors - Presonus does not provide (nor appear to have in development) offline editors. To set up a show, one must be connected to the mixer. Major PITA. A third party has produced a minimal editor that supports the 16.4.2 and the 24.4.2, but not the 16.0.2 (he doesn't have one to test and keep current with). I'm sure Presonus could buy the guy out, license it, or at least give him a 16.0.2 to work with. I don't think that is something Presonus sees as necessary.
I've been using my purchased new 16.0.2 since August 2011 without incident. I've recently purchased a 24.4.2 and am spoiled by the additional things the mixer does. The 16.4.2 is more similar (function, size, weight) to the 24 channel than the baby 16.0.2.
Mine are the non-AI mixers. Can't comment on the new ones. I do get the feeling that the older mixers have seen all the firmware/software development they will ever see.
I can't complain about the sound - or really compare. Customers are happy. I guess we could get into bit-depth discussions, but that is beyond my level of concern.
Firewire interface. My Mac - pre thunderbolt - was plug and go. Bought it to replace my Dell...
My Dell with on-board firewire was an unmitigated disaster. Ricoh chipset does not work. Need a TI chipset via a PCMCIA (or whatever its replacement is...). XP is no longer supported. With Windows 7, I spent hours (days?) working trying to get priorities, drivers, interrupts, etc. so that the Universal Control program was "stable" - which is needed for IPad control. Capture, its multitrack recording software, has to run on the same computer at the same time as universal control. That goes back to tweaking the priorities, drivers, interrupts, etc. so the program will operate without dropouts or generalized barfing.
MY EXPERIENCE (YMMV) was that I could not get my Dell with Win 7 to work reliably with Universal Control. Capture was a lost cause. TO BE FAIR, Many folks run Windows 7 and 8 without any of the drama I experienced.
From a "future proofing" standpoint, I would not purchase the 16.0.2 again - many likes of the board, but there are so many new mixers coming out in the low price range, (A&H, Soundcraft) I'd have to think about something else. The new Presonus did not address some of the critic's concerns with the new ones. I do not think to second guess the manufacturing/marketing of the company. I see facts.
Size/features of the 16.0.2 is a good combo for what, in reality, is a 12 channel mixer. I do believe it is better (for me) than the micro-digital-mixers like the Mackie and the QSC, but again, weight of tradeoffs.
frank
Based on your stated needs, I recommend a Soundcraft Expression 1. Its' a 16 channel board that has a slot to make it capable of having additional inputs. It also has more outputs than the others mentioned, great for multiple monitor mixes and other uses.
I have a LS9-32 and then bought the Presonus SL16, SL24 and eventually the baby SL16 to add to the collection. I really like the Presonus for its QUICK ease of use, sound and its features. After installing a SC Expression 3 in a church last summer, I really wanted one. I sold my SL16.4.2 and bought an Expression 2. I recently had a little drive time on the A&H QU-16, but didn't care for the user interface too much, though I've always loved A&H products. I've owned the Mix Wizard and several different models of the GL series. I'm sure the QU-16 sounds great, but IMO it wasn't the easiest transition from analog when compared to the Presonus and Soundcraft. I picked up operation of the Presonus quickly and the Soundcraft was even quicker.
I will be holding onto my SL24 for a while, besides its nice feature set and sound, it also has a very nice recording feature and comes with 3 discs of software. One of my best clients is tied to this board because of the recording feature.
Garry W
[FONT=arial, sans-serif]Does the Souncraft digital board have the ability to record direct to USB drive like the A&H Qu boards ?
Thanks[/FONT]
