Lighting & Electrical
Another hazard
<blockquote data-quote="Silas Pradetto" data-source="post: 5490" data-attributes="member: 34"><p>I hope whoever built this is on the forum, so they can fix it as soon as possible before someone gets hurt.</p><p></p><p>I found this on Facebook - not sure if has been posted before.</p><p></p><p>Problems I see:</p><ul> <li data-xf-list-type="ul"><strong>Californias on the panel are the wrong gender!!!!</strong></li> <li data-xf-list-type="ul">Wire on Californias is too small - likely 6/4</li> <li data-xf-list-type="ul">Someone doesn't know what conduit is for - or at least use offset nipples for everything</li> <li data-xf-list-type="ul">SE / SER clamps are not suitable for rubber cord</li> <li data-xf-list-type="ul">Also, the panel could at least be a weather resistant model, not an indoor model. Even better if it used bolt-on breakers since it's moving around a lot.</li> </ul><p></p><p></p><p>Discuss:</p><p></p><p>[ATTACH]156730[/ATTACH]</p></blockquote><p></p>
[QUOTE="Silas Pradetto, post: 5490, member: 34"] I hope whoever built this is on the forum, so they can fix it as soon as possible before someone gets hurt. I found this on Facebook - not sure if has been posted before. Problems I see: [LIST] [*][B]Californias on the panel are the wrong gender!!!![/B] [*]Wire on Californias is too small - likely 6/4 [*]Someone doesn't know what conduit is for - or at least use offset nipples for everything [*]SE / SER clamps are not suitable for rubber cord [*]Also, the panel could at least be a weather resistant model, not an indoor model. Even better if it used bolt-on breakers since it's moving around a lot. [/LIST] Discuss: [ATTACH=CONFIG]156730.vB5-legacyid=4855[/ATTACH] [/QUOTE]
Another hazard
