ProRack-House (H1020)
Great Analog Mixer looking for buyer.
The functionality of this mixer is amazing for the size. It is in like new condition.
I have used the mixer about 5 times for shows and have stored in closed mixer case the rest of the time.
Bought as B stock. Looked brand new from factory. No sign of wear.
Shortly after getting the mixer I stopped running sound for my band. It sells new for $2650-2900.
I will sell it for $2100, OBO. Buyer pays shipping. Location is Columbia, SC. eight 0 three four 6 three 5 eight 7 four
or PM me
Please Spread the word.~:-D~:grin:
Here's a pro pics from the website
[TABLE="width: 95%, align: center"]Great Analog Mixer looking for buyer.
or PM me
[TR]
[TD="colspan: 2"] ProRack-House (H1020) Feature Overview:[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
- 20 Microphone pre-amplifiers in total. 12 Mono mic/line input channels and 4 Dual-Mono/Stereo mic/line input channels, all with Spectra-quality microphone preamplifiers in a 10u (17.5" in x 19") package.
- Minimum phase shift circuitry and internal Mother Board/Daughter Board construction derived from the Spectra console design.
- 48 volt Phantom Power switch, Polarity Reverse switch, Mic/Line switch, Mic Pad switch on input channels. (Combo mic/line/pad switch on stereo input channels).
- Variable frequency high-pass filters on all Mono and Stereo input channels with a 20Hz to 400Hz sweep range at 12dB per octave.
- Mono input channels feature fixed high and low frequency EQ bands and two mid-sweep EQ bands, with EQ On switch with LED. The Stereo channels feature fixed high and low frequency EQ bands and a single mid-sweep EQ based on Spectra circuitry.
- Six aux sends; each pair of sends switchable between a pre or post fader source. In the pre-fader position, an additional front panel switch determines if that pre-fader signal is derived pre or post EQ. Aux controls 5 and 6 may be switched to become a stereo pair.
- All channels can assign to Left-Right, Center and Mono mix bus assignment along with additional assignment switches to subgroups 1-2 and 3-4. These outputs (including aux outputs) each have balanced XLR outputs, TRS bus inputs and TRS insert connectors.
- Left-Right, Center and Mono mix output level can be switched from line level to mic level.
- Internally illuminated Mute and PFL/AFL switches along with 6-segment LED channel metering and 100mm faders on all input channels.
- Four LED meters can monitor the Left, Right, Center and Mono outputs or the Group 1-4 outputs. Meters auto-switch to show Solo levels.
- Bus level signal monitoring using bi-color LED's on all 14 mix buses: Left, Right, Center, and Mono, Groups 1-4, and Aux 1-6.
- 100-240 VAC, 50/60Hz Power Supply - Field replaceable (plug in) without disassembly of mixer.
- Rear panel rotates and may be locked in any of three preset angles (referenced to the front panel) - 90 degrees, 135 degrees, or 180 degrees.
- Adjustable lamp dimmer provided for the 4-Pin XLR connector for use with (optional) gooseneck lamp.
[/TR]
[/TABLE]
[TR]
[TD="colspan: 2"][TABLE="width: 100%"]
[TR]
[TD="class: header3, colspan: 2"]ProRack-House (H1020) Specifications:[/TD]
[/TR]
[TR="class: style30"]
[TD]Frequency Response (Any input to any output)[/TD]
[TD]+0/-0.5dB 20Hz to 20kHz (ref to 1kHz)[/TD]
[/TR]
[TD]Phase Response (Mic input to Main Output)[/TD]
[TD]+10/-15 degrees, 20Hz to 20kHz (ref 1kHz)[/TD]
[/TR]
[TD]THD + Noise (Mic Input to Main Output)[/TD]
[TD]<0.01% @ 15dBu output[/TD]
[/TR]
[TD]
Noise: All measurements ref to 20Hz to 20kHz Bandwidth unless noted. Mic EIN
[/TD][TD]-128dBu @ 60dB gain, 150 ohm source[/TD]
[/TR]
[TD]Main Bus (L-R-C-M) Output Noise[/TD]
[TD]-85dBu (all Channels assigned w/faders down, Master fader at unity).[/TD]
[/TR]
[TD]Group Bus Output Noise[/TD]
[TD]-85dBu (all Channels assigned w/faders down. Group fader at unity).[/TD]
[/TR]
[TD]Aux Bus Output Noise[/TD]
[TD]-90dBu (Aux Sends down. Aux Master at unity).[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]Interconnect Features (H1020):
- Direct outputs on all input channels.
- Inserts on all Mono input channels, Aux, Group, and Main outputs.
- Bus inputs on all 14 mix buses (Aux, Groups, Mains) to allow for easy expansion through linking of units.
- Both 1/4" and 1/8" Headphone connectors are provided.
[/TR]
[/TABLE]
