I just bought two 1100 watt crunch amps. Each amp is powering it's own 12" sub. Each amp has it's own 4 gauge wire with a sixty amp fuse powering it both coming strait from the battery. The grounds are also four gauge and are connected to the body. My problem is that when both amps are connected and running the subs sound terrible. They a quiet and don't sound deep or good at all. But if you disconnect the RCA from one amp the other sub sounds great it's loud. Its as if there is not enough power for both amps and only one amp can be powered effectively. What can I do to make both amps run at full power so both subs sound good?
