Junior Varsity
Audio Signal Distribution Questions
<blockquote data-quote="Doug Waller" data-source="post: 3359" data-attributes="member: 1253"><p>Hello everyone,</p><p></p><p>I am tasked with setting up a system in which there is one input (audio from an ipod) sent out to three different speakers, each of which has to have their own individual level control. Through some research, I found the <a href="http://www.planetdj.com/i--SD-2418" target="_blank">Nady SD2418</a>. </p><p></p><p>Questions:</p><p></p><p>Does this device go before or after the amplifier?</p><p>If it goes after, will the signal be cut as many times as the signal is split?</p><p>If it goes before, do I need an amp for each individual output?</p><p></p><p>Thank you so much for any help,</p><p></p><p>Doug</p></blockquote><p></p>
[QUOTE="Doug Waller, post: 3359, member: 1253"] Hello everyone, I am tasked with setting up a system in which there is one input (audio from an ipod) sent out to three different speakers, each of which has to have their own individual level control. Through some research, I found the [URL="http://www.planetdj.com/i--SD-2418"]Nady SD2418[/URL]. Questions: Does this device go before or after the amplifier? If it goes after, will the signal be cut as many times as the signal is split? If it goes before, do I need an amp for each individual output? Thank you so much for any help, Doug [/QUOTE]
Junior Varsity
