B&C DE800 1.4" Exit 3" V.C. Titanium/Polyimide Neo HF Driver
Neodymium 1.4" exit HF driver with 3" voice coil and titanium diaphragm with polyimide suspension. New, never mounted. Smudged logo on label, otherwise perfect. 8 ohms. Same driver that comes as part of the B&C WGX800 waveguide source. Can also be found in some Adamson boxes. Retail/MAP $434.65. $200 plus shipping.
B&C DE1060BST 2" Exit 4" V.C. Titanium Neo HF Driver
This is an OEM version of one of B&C's top-of-the-line drivers. It is a variant of their DE1050 and features a 4" voice coil and titanium diaphragm, copper shorting cap on the pole piece, and a large neodymium ring magnet. The only difference I can find between it and a DE1050 is the DE1060BST has set screw input terminals. Never used. Tested and functions perfectly. 109 dB 1W/1m, 8 ohms, 140 watts RMS, 8 lbs. Retail/MAP: $599.95 (DE1050). $300 plus shipping.
Eminence Acoustinator N2012 Neo 12" Guitar Speaker (x 2)
Features a neodymium magnet structure, polypropylene cone with Santoprene edge, and stamped steel frame. 8 ohms, 150 watts RMS, 94.7 dB sensitivity. Designed for acoustic guitar amplification or other stage instruments that require an uncolored, full-range sound. Engineering samples in excellent, unused condition. 4.3 lbs. each. Sold as a pair. Retail/MAP $154.99 each. $75/pair plus shipping.
Images are of the actual items, which are located in SW Ohio. I can email additional pictures or more information upon request. I will only ship to addresses in the continental US. PayPal is okay.
Best way to contact me is via email: mike dot smith at eventtechnicalsystems dot com.
